Working with offsetter
  • December 4, 2019
  • 27 views
Hi
I'm trying to tranform a shape file to 3d tiles and adding a offsetter in between to adjust the zmin of the shapefile data.It was working fine and i saved the workspace .But when I'm using the same workspace to convert other shape file data,I'm getting the output but the attributes of the data are from the old data only.
I'm not getting the attributes of the new file ,the old file attributes are only present which are coming as null. The old attributes are not replaced by the attributes of the new file.
How to achieve the transformation of different files with their respective attributes with the same workspace with the offsetter.
I have attached a screenshot of data and the workspace.
oscard
Forum|alt.badge.img+21
  • December 4, 2019
