Extract DWG files from Postgres by recent Date
mr_fme
Forum|alt.badge.img+7
I have one postgres table with DWG features recorded, the features are from many files, the files name is in filename column.
Look that the kind column, there are 3 different kind...I, II and III. In others words one specifical filename can be of the 3 kinds in the same time. Because the same DWG file was recorded in Postgres considering the 3 differents models of the drawing.
Note: all features belonging to same file have the same file_date.
In short I need to extract all features group by filename but considering the most recent file_date
Maybe I was clear?
Thank´s
gio
Forum|alt.badge.img+15
  • January 22, 2019
@mr_fme
If you wish to use fme transformer's for that:
Then you can use Statistics Calculator analyse the date filed and group by filename.
As Statistics Calculator works on date fields.
Of course you can do same using a Postgres query:
select max(date)
from table
group by filename
Forum|alt.badge.img+48
Making sure if I understand you correctly:
In this example the most recent date for the file 158-Maria_Farm_01 is 08-22-2019 so you only want to extract that feature?
mr_fme
  • January 22, 2019
No, all feature belonging to 158-Maria_Farm_01 with 08-22-2019 (if most recent), in short means all features from the same dwg file. Example: features with Kind = I, filename = 158-Maria_Farm_01, file_date 08-22-2019...equals same DWG.
mr_fme
  • January 22, 2019
I solve my problem using StringReplacer, DateTimeConverter before StatisticCalculator...after FeatureMerger
Thank´s
