Connections partially disappearing at runtime
chriswilson
Forum|alt.badge.img+11
I may have missed something, but when I run the workspace I'm working on right now one of the connections - between a Sorter and an XMLTemplater - partially disappears and only shows behind the feature count. See the attached screenshot. Any ideas there?
This is in 2017.1.1 build 17650, 64-bit.
Forum|alt.badge.img+49
That looks like a visual bug. If it's reproducible I'd recommend sending it in to Safe's support.
  • October 26, 2017
Agree. I've never seen anything like it.
chriswilson
  • October 27, 2017
Thanks guys, I'll send it in. It does happen elsewhere in the workspace between those two same transformers.
