Strange Coordinate System
ingalla
Forum|alt.badge.img+10
Hello
I have some GPS data from a dashcam which contains a strange coordinate system which i have never sen before, I am guessing it is decimal degrees but can not be certain. Does anyone have any ideas as to what it is and more importantly how to convert it to British National Grid.
Thanks in advance
Andy
erik_jan
Forum|alt.badge.img+17
  • November 27, 2017
If it is UK it looks like N 51 degrees, 01.0869 minutes and w 001 degrees, 04.9518 minutes
That seems to be in the right place, using WGS84 it would put it here:
ingalla
  • November 27, 2017
Erik @erik_jan
Thanks for your answer, and i seem to be getting somewhere, but i need to get the points onto the road the A32, see attached fme1.jpg, i have also included a snip of the workbench with everything other than the vertex creator stripped out in fme2.jpg
Thanks for your help
