I currently have the feature passing through a CenterPointReplacer (in order to associate the feature to a .cel file it needs to be a point) then a DGNStyler to choose the appropraite .cel file. In the DGNStyler I choose FME_Rotation for the Cell Rotation but the cells still come in at the same angle. I'm not sure if this is caused by the fact that i'm trying to rotate a point feaure?
