Accessing ubuntu server from FME
  • November 17, 2015
  • 17 views
Dear FME community,
is there a way to connect to an linux/ubuntu server from within FME Desktop? We have a server which has a specific IP adress. Say e.g.: 123.45.67.89
On this server which is a virtual machine runs Ubuntu. We would like to read from this server and if possible update the files in a specific linux folder. Is there a way from within FME to gain access to an ubuntu server?
Kind regards
Thomas
  • November 17, 2015
Hi
The easiest is probably to just set up a Samba share on your ubuntu server and access it as a regular network share from your Windows machine.
If that isn't an option, you could set up a secure ftp server and access that directly from FME.
David
  • August 24, 2016
It is a good idea to have a SSHExecutor transformer. Also, you can use ssh module in PythonCaller.
