Note new ShortestPathFinder may erase coordinate system
This is not a question but an information. FME2013 ShortestPathFinder has become quite easier-to-use than the previous version. But features from PATH port lost coordinate system in my environment - FME2013 Build 13261 WIN32 and Windows Xp SP3 32-bit. Check this workspace if you are interested in this issue: https://www.dropbox.com/s/h3ne8q6s17rkb9j/TestShortestPathFinder.fmw
  • January 21, 2013
It seems to be a problem specific to released FME 2013, for references not happening on the previous released FME versions...
fmelizard
Forum|alt.badge.img+18
  • January 21, 2013
SOrry about this one, we'll address it for FME 2013 SP1
  • January 23, 2013
To avoid a coordinatesystem-less output: add a CoordinateSystemSetter.
  • April 23, 2013
I confirmed this problem has been solved in FME 2013 SP1.
Thanks.
