Writing annotation
I'm trying to find a way to write to an Annotation Class in a File GDB. I've figured how to write correctly the text I'm reading from coverage input data, but when reprojecting in ArcMap all my labels won't reproject.
Is there a way to write annotation that can be reprojected normally using ArcMap?
Thanks,
fmelizard
Forum|alt.badge.img+18
  • October 8, 2013
There should be no problem reprojecting annotation, are you sure that the text you are writing is correctly written as  annotation ?
  • October 8, 2013
also make sure that the output feature class has a defined coordinate system. You can use ArcCatalog and go to the feature class' Properties dialog to verify this.
David
  • October 8, 2013
I checked me feature class is set as WGS84.
My writer definition is as follow : Allow geometry : geodb_annotation
