Watermarking rasters
  • February 20, 2015
  • 57 views
Hi All,
I have some thematic charts (1 band, paletted) that I'd like to try and add a fixed-image (created with MapnikRasterizer (4 band)) watermark to one of the corners of.
Does anyone have any suggestions for how to do this?
- RasterMosaicker is out because the two images have different numbers of bands.
- MapnikRasterizer almost certainly could, but I'm concerned it will alter the charts in some way beyond the watermarking (location, size, projection, paletting, imagery, etc) which is an absolute no-no.
Before I set about trying to use MR to do this, does anyone have any other suggestions? Or even suggestions for how to use MR to do it.
Thanks,
Jonathan
gio
Forum|alt.badge.img+15
  • February 20, 2015
Maybe use a rasterexpressioncalculator/evaluator on relevant bands?
  • February 21, 2015
Hi Jonathan,
I think you can do mosaic them after coercing interpretation of the chart to RGBA32. Have a look at these transformers.
RasterPaletteResolver
RasterInterpretationCoercer
Takashi
