How to change the baseURL of fmeserver?
Hello...
by default the FMEServer-URL is <server>:<port>/fmeserver. Is there a way to change this URL to lets say <server>:<port>/apps/fmeserver?
Thanks in advance for any hints :-)
Best answer by xiaomengatsafe
Hi @stefangiese, Unfortunately, I don't think we support changing FME Server Web URL. If this is important in your workflow, would you mind posting this as an Idea, and share some more detail with on what is the reason for changing the URL? Thank you very much!
xiaomengatsafe
Forum|alt.badge.img+3
todd_davis
Forum|alt.badge.img+21
  • July 31, 2018
Hi, If you really need it and don't mind having both <server>:<port>/fmeserver and <server>:<port>/apps/fmeserver, you could use a url rewrite like this example
https://knowledge.safe.com/articles/632/using-iis-and-arr-as-a-reverse-proxy.html
