My workspace try to writer in a Table in ArcSDE, but doens't work.
Has a way to get the error message from ArcSDE? Similar we have the ora_error for Oracle.
Thanks,
Danilo
Thanks,
Danilo
Best answer by lenaatsafe
Hi @danilo_inovacao
would it help to scan the log (as a text file) and find all strings that contain |ERROR| ? If a transformer rejects a feature, quite often (and I hope soon always) there will be an attribute added to the feature that explains the reason of rejection. However, in your case the feature is rejected by the Writer... it wouldn't be helpful to add anything to the rejected feature in this case.
