Archived
Allow connection style to be saved in the workspace
Related products:FME Form
taojunabc
Participant
Fme 2018 allows users to set the connection style. I personally use Curved, but not all workspaces are suitable for this style, especially if I open a workspace created by someone else with Squared or Straight. It gets a mess, so I want to save the connection style as a property of the workspace and the workspace.
mhab
Forum|alt.badge.img+10
  • September 23, 2018
I would like to add, that the setting should be acessible from menu Tools/FME Options/Appearance or similar like Workspace ...
I find it confusing if it is not there.
Forum|alt.badge.img+48
I think this should remain a personal preference. However, I do agree with @mhab that the setting should be in the FME Options / Appearance window.
