matching keywords with table ?
charlesdollat
Participant
HI !
i'm starting using FME 2018 and i would like to do something very special i don't know if i can do it ?
So,
i want to match two table with one attribute but sometimes this attribute is not the same in both.
exemple :
Table 1 :
"restaurant le Bistrot"
Table 2 :
"auberge le bistrot"
the special key word are not always at the same place.
my first idea was to separate every word from one of these table in list with attributesplitter and using a "tester" searching at least 2 word from lists for making a match with my first Table but that doesn work. even with "matcher"
do you know if my request is possible ?
thanks !!
Charles.
danilo_fme
Forum|alt.badge.img+41
  • April 6, 2022
Hi @charlesdollat​
Did you try to use the custom transformer for fuzzy?
FuzzyStringCompareFrom2Datasets
Thanks in Advance,
Danilo
charlesdollat
Participant
  • Participant
  • April 7, 2022
danilo_fme wrote:
Hi @charlesdollat​
Thanks in Advance,
Danilo
Thank you for your answer ! this transformer seems to be perfect.
Unfortunately, i have an erreur message :
Python Exception <AttributeError>: 'NoneType' object has no attribute 'lower'
i think it's because i have some numbers in my attributes,
thank,
danilo_fme
  • April 7, 2022
Please @charlesdollat​
Could you send me a sample your data?
