Tester - filter values that contain "text. (anynumber)"
I would like to ask how can I filter data by using Tester consider condition:
ATTRIBUTE_ABC - contains - "max. 1" or
ATTRIBUTE_ABC - contains - "max. 2" or "max. 3" etc.
how can I generalize Tester by substituting number 1, 2 or 3... to don't build x number of testers.
oscard
Forum|alt.badge.img+21
  • March 27, 2018
I would use the condition:
ATTRIBUTE_ABC -> Begins with -> max.
  • March 27, 2018
Hi @oscard
attribute value looks for instance like this - > abc max. 20A
I need to check if person who collected data didn't omit numeric value like "20A" or "40A" etc
That's why I'm thinking to use
ATTRIBUTE_ABC -> CONTAINS -> .....
However, I don't know how to create general condition for "right value" in tester.
  • March 27, 2018
Hi @vid, the "Contains Regex" operator can be used to test the pattern of string (Left Value). For example, this regex (Right Value) matches a string consisting of literal "abc max. ", one or more number, and literal "A".
^abc max\. \d+A$
  • "abc max. 20A" -> Passed
  • "abc max. 20B" -> Failed
  • "abc min. 20A" -> Failed
and so on
