Hi ,
Recently we have upgraded our FME Desktop version from FME 2021 to FME 2022. Since then to Fetch data from Esri ArcGIS Portal Feature Service (Reader) is very low. Even to fetch around 10k records it takes about 10 mins, However in FME 2021 it was working very well and it takes about only few seconds only to fetch the same size of records. Is this a known issue with FME 2022?
