Pivot rows to columns
nedwaterman
Forum|alt.badge.img+9
Why isn't this easier in FME? I've tried lots of examples on the Hub, but can't get any of them to work. The Attribute Pivoter is difficult to use and never gives me the results I need. I can perform this very easily in SQL.
I'm trying to turn my rows Vxx into columns with the value of Litres, grouped by all the other rows. Any idea how I can achieve this? Thanks in advance!
Best answer by ebygomm
@nedwaterman Example workspace attached - it's in 2019.2 - it'll warn about the workspace not being compatible but should open correctly
pivot.fmwt
Forum|alt.badge.img+31
  • March 19, 2020
Can you give an example of what the output should look like?
nedwaterman
  • March 19, 2020
Certainly - find it attached!example.xlsx
  • March 19, 2020
I nearly always use pivot data by using the value of an attribute to create a new attribute with that name, then aggregate and merge attributes and expose the newly created attributes
You can import the values from the period column in the original input in the AttributeExposer
Gives this output
  • March 19, 2020
You can use the attribute pivoter though as well, you still need to expose the attributes if you want to see them on the canvas
The attribute pivoter does set up a schema for you which makes it slightly more straightforward to write th data out dynamically without exposing the attributes
nedwaterman
  • March 19, 2020
Gives this output
That would be perfect. Would you mind sending me your workflow? I'm on 2019.1.
Thank you very much for taking the time to help me with this - it's been driving me mad!
  • March 19, 2020
pivot.fmwt
nedwaterman
  • March 19, 2020
Thanks very much ebgygomm - I've used this approach and it works beautifully. You've saved me from insanity!
nedwaterman
  • March 19, 2020
pivot.fmwt
Thank you - you have been a great help!
smclaugh1
Forum|alt.badge.img+5
  • September 29, 2022
@ebygomm​
Thanks for the great pivot examples, these are perfect.
