Insert record in table postgres
  • February 18, 2019
  • 38 views
checcosisani
Forum|alt.badge.img+12
Hi all
I'm sorry probably my SQL knowledge is too less but I tried to append some records to an existing table postgresql but I received this error
Bulk copy failed on table 'Slist_ITA.List_StreetName' using delimiter ':'. Error was 'ERRORE: un valore chiave duplicato viola il vincolo univoco "List_StreetName_pkey"
DETAIL: La chiave (id)=(3554) esiste già .
CONTEXT: COPY List_StreetName, riga 1
... Last line repeated 2 times ...
I attach also the picture of wb (very simple)
Thx for help
Francesco
  • February 18, 2019
Looks like you have a duplicate primary key on the "id" column when inserting the new records.
If this is a one-off workspace you can manually find the largest value of "id" in the existing table and the use a Counter to set new "id" values starting on that value + 1.
checcosisani
  • February 18, 2019
Hi
I tried to check if some duplicates are present but no duplicate but the ID is mandatory ?
I tried also to create new id with new values but always errror
thx
Francesco
checcosisani
  • February 18, 2019
Hi
solved
I recreated the id in the postgres table and now it works
thx
Francesco
checcosisani
  • February 19, 2019
Hi all again...
sorry I know my limit in POstgreSQL but where I can find a good tutorial to migrate MS Access DB in PostgreSQL ?
thx for help
Francesco
