binary characters
fmesafe.podpora
Forum|alt.badge.img+11
Hello,
I would like to ask. If you look at the attached file with an editor that can display binary characters, you will see how individual requests start with these binary characters ( ef-bb-bf ). Why do these signs occur? How do I remove them?
Thank you
  • March 22, 2023
It's probably the BOM. You can turn it off in the text file writer, if necessary.
fmesafe.podpora
Hi, disabling this feature solved the problem.
Thank you
