Web connection issue related to SalesForce
arthy
Forum|alt.badge.img+8
Hello,
I have a SalesForce account that is working but for somehow I'm not able to read data with FME.
When setting my account, it was first asking me my username and my password
MicrosoftTeams-image (2)
 After fixing this, now I'm not being able to create the web coinnection for Saleforces. I'm only receiving the following error message .image.png I went to manage web connection and tried to test the web service for Saleforces but still the same error.
image.pngAny ideas?
JennaKAtSafe
Forum|alt.badge.img+7
Hi @arthy​, are you creating a new web service by using the Salesforce web service template? The error message is also coming from Salesforce, also wondering if you've edited the existing template.
gedgg
  • October 4, 2023
@arthy​ did you manage to find solution? Experiencing same issue.
arthy
  • October 16, 2023
No @gedgg​. I haven't
gedgg
  • October 18, 2023
@arthy​  in my case it turns out that IT has switched off API access privileges from my account blocking me from accessing Salesforce programmatically.
