Loading a large amount of features to Test on?
Hello all,
I have a large number of points (over 15,000) in the same geographical (x,y) location that I need to filter out. I cannot do this spatially and there is no coordinate data in the points. There is only one attribute within the data I can use to filter on (Address).
I have a spreadsheet that has a "Town" column that has over 3500 rows.
Is there anyway of bulk testing the Address attribute against the Town column from the spreadsheet to filter down the data? I don't want to copy and paste 3500 Town names into a Tester if I can avoid it!
Thanks,
Jeff.
Best answer by daveatsafe
Hi @juffers,
You can use the DatabaseJoiner transformer to join your data to the spreadsheet Town column. Any features that do not find a match will be output through the Unjoined port of the transformer, making it an effective filter.
daveatsafe
Forum|alt.badge.img+19
  • May 14, 2018
Hi @juffers,
  • July 21, 2018
Thanks for the answer
