Does anybody know what name should be entered for the Address point in an INSPIRE Addresses xml? I have tried all kinds of names in the GeometryNameSetter transformer.
Have you tried the new INSPIRE Writer in FME2014? Here you can auto-populate the Writer-attributes for all INSPIRE Schemas. See the recorded webinar how to do this trick: How to Create and Share INSPIRE-Compliant Data with FME :
Yes, I have seen the Webinar and Yes, I am using the 2014 Inspire writer.
But, as shown in the webinar with the Cadastral parcels demo, the geometry in the Inspire writer has to get a name using the GeometryPropertySetter transformer.
For Cadastral parcels (shown in the webinar) that name is "geometry" or "referencePoint".
I am looking for the right name for points in my Addresses dataset.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
