orientate parallels lines
alc33
Forum|alt.badge.img+10
Hi !
I have a line with his orientation.
I would like to orientate parallels lines on the same way.
Do you have an idea?
Thanks !
dustin
Forum|alt.badge.img+30
  • June 21, 2022
I've attached a workbench that I think will do what you are asking. It basically analyzes the angle of the line, buffers that line, then chops the buffer keeping the parallel lines. The offset distance can be changed in the Bufferer transformer.image
alc33
  • June 24, 2022
Thank you very much @dustin​ I will try this !
