Flatten File
I've got output from 3 statscalculators coming together to create the following and was wondering how I could 'flatten' it such that that one record exists for each community and <missing> values have a value of zero.
So the output would look like the excel image.
Best answer by takashi
Hi @aviveiro, the Aggregator (Group By: COMMUNITY, Accumulation Mode: Merge Incoming Attributes) might help you. Then, to assign zero to missing attributes, consider using the NullAttributeMapper.
  • March 9, 2018
  • March 10, 2018
Terrific @takashi !
Your suggestions worked.
Thank you.
