How can I extract certain lines from a logfile (txt)
  • December 13, 2019
  • 62 views
Hi, I'm new at FME and want to do the following:
there's a process running at our server which is logged every night. We would like to get a warning when certain errorcodes pop up in the logfile.
For those (= [ERROR] and [WARN ]) of that night (filter on date of today) the whole line should be placed in another file.
The file looks like this:
2019-12-10 12:45:58,644 [WARN ] TrfAgiv.TrfCeviErrorHelper terreinobject 7654048 - CRCODE 'aardTerreinobject' - 'grbAdmPerceel' (6004) wordt niet verwerkt (NAARGEM = 0)
2019-12-10 12:45:58,646 [ERROR] TrfAgiv.TrfCeviErrorHelper terreinobject-huisnummer 20903264 - Niet alle noodzakelijke bovenliggende gegevens werden gevonden.
2019-12-10 12:45:58,647 [DEBUG] TrfAgiv.TrfCeviHelperEf terreinobject-huisnummer id: 20903322
2019-12-10 12:45:58,874 [DEBUG] TrfAgiv.TrfCeviHelperEf --> straatnaam id: 55794 opslaan, synchroniseren: False
There's an exemple of the file attached.
What would be the best way to go?
Thanks!
Isa
logfile.txt
You can have a process that runs after the workspace from your log is finished, that reads this log as textfile and use a tester to look for lines with the Errors and Warns (Using "Contains") that you want to filter then save it.
Or a LogMessageStreamer in your workspace, then select the TAG that you want and save it. You can be more specific using a tester using "Contains" in the log message after the TAG selection.
erik_jan
Forum|alt.badge.img+17
  • December 13, 2019
FME has the option to filter log messages.
Have a look at the options menu in FME Desktop:
warrendev
Forum|alt.badge.img+23
  • December 13, 2019
Using the python shutdown script is the way I go about parsing the log files.
Here is some good information going over how to set it up.
https://knowledge.safe.com/questions/60186/capturing-errors-in-fme-server-log-files.html
  • December 16, 2019
Thanks for the quick reply everybody!
@rodrigo_ferrao I think I will go with your first option. I was trying with the stringsearcher before but I kept getting stuck building the regular exporession.
@erik_jan Thanks for the answer. But the process is not runing in FME (server). It's a totally different process and by scanning that log we hope to get a better view on things when it goes wrong. (kind of a black box right now)
@warrengis thanks for the answer: I'm almost there using the tester transformer but this info can get in handy another time!
