Why does ArcGIS read the wrong projection after using EsriReprojector?
  • March 28, 2017
  • 12 views
I am trying to reproject an ECW image from EPSG:31467 to EPSG:25832 with FME 2017. After reprojecting using either "Reprojector" or the "EsriReprojector" the output coordinate system is always NUTM32 even though I specifically assigned "ETRS_1989_UTM_Zone_32N". The Coordinates are also totally wrong lying 3000km east of where they should be. Can anyone explain what I am doing wrong?
This is then not
  • April 20, 2017
If you have anything in the Coordinate System parameter of the writer it will reproject to that upon writing, after the reprojector transformer(s). Make sure it is blank and it will take the CRS of the input data or whatever the transformer sets.
