Error overwriting ArcGIS Portal layer
  • January 23, 2021
  • 17 views
cecshi25
Forum|alt.badge.img+3
I was able to create a hosted feature using the same model, but when I switched the writer to update that same layer, it kept giving me this error:
"ArcGIS Portal Feature Service Writer: Could not recognize Feature Service coordinate system '{}'
Python Exception <KeyError>: 'capabilities'
A fatal error has occurred. Check the logfile above for details"
Coordinate System set to EPSG:4326
Portal Feature Write set to Insert and Truncate
Anyone knows how to fix this? Thanks!!
FME_Issue
  • March 31, 2021
Have the same issue in FME Desktop 2017 x32. Any news/ideas? It seems like common issue with FME and Portal feature service writers. Never succeed in trying to write to the Portal DataStore.
