I have balcony drawings as attached files two sample data. I want to calculate the thickness of the balconies as seen in the picture. is there a transformer for that?
Balcony thickness calculate
Best answer by nielsgerrits
nielsgerrits wrote:
Added sample workspace.
I would exclude short lines from the analysis. Shorter than 0.3m worked fine for your samples. But feel free to experiment what works best yourself.
- LengthCalculator after the Chopper
- Tester after the LengthCalculator, _length > 0.3
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
