How can a user enter a field value which will be used in an SQL query in the server schema?
  • September 29, 2014
  • 7 views
I would like to know how to do the following operation with FME Server:
I have an Oracle table from which I want to read some records with a given field value. I want to use an Oracle Spatial Reader with SQL query. I want to implement it with FME Server, and I want the user to enter the field value, which is used in the SQL query.
An example: At the Oracle Spatial table there is a field called "selector". I would like to create a schema with an Oracle reader with an SQL query.
Select * from table_name
Where selector = XXX
XXX=is the value the user enter in order to activate the server schema,
Thanks.
Best answer by dcam
First thing to do is create a published parameter called “selector_value’:
When you run your workspace on the FMEServer, you can set it up so your user will be prompted to enter a value for the selector_value.
In your reader where statement set it up like below so the statement uses the parameter value:
Selector = ‘$(selector_value)’
Then that should read only the features with the selector_value.
