Hi there,
I have an Ascii grid file.
The FME can read the file I have also added a Raster Cell Coercer transformer to create a shafile this simple workbench works fine.
Issue - How the raster values can be displayed in the shapefile. The shapefile has no attribute data (cell values).
I need to display the raster values in the shapefile. Any hints will be greatly appreciated.
Thank you very much,
Sebastian Algardi-Camus
