When loading MasterMap can I choose identical schema?
Best answer by ian_mitchell
a bit more info for this one ... I'm running a process which reads a set of OS MasterMap topo GZ files extracts some specific Topo Areas and writes them to TAB
just a question about the Reader ... can I tick the box that says "Identical Schema"? ... is it worth doing? does it make a difference to speed (or anything else) or how does it change the processing?
many thanks
IanM
