Archived
SOAP WS-Security
Related products:Transformers
  • siennaatsafe
    siennaatsafe
  • fgiron
    fgiron
  • jurgenmack
    jurgenmack
  • mdfwrestler
I’m trying to call a SOAP service from FME Desktop using the HTTPCaller. This service is secured with WS-Security and requires a username token and digital signature (from a PKCS#12 bundle). I’ve managed to get this working in SoapUI by following this documentation. Is there any way to apply this type of security in FME Workbench?
Thanks in advance!
  • December 19, 2017
I've done something similar, although it seems my setup was somewhat simpler. I was able to make it work in FME by importing the p12 certificate into the Windows keychain, transformers like the HTTPCaller will then use it automatically.
If that doesn't work, you may have to break out a Python script.
PS: Maybe you wanted to post this as a question and not as an idea?
jurgenmack
Forum|alt.badge.img+9
  • January 3, 2018
@david_r
Hi David is it a p12 file you need; I am using .crt files
  • January 4, 2018
Have you tried converting the .crt to .p12 so that you can import the certificate into the Windows certificate store?
There are instructions for how to do this here: https://pubs.vmware.com/view-51/index.jsp?topic=%2Fcom.vmware.view.certificates.doc%2FGUID-17AD1631-E6D6-4853-8D9B-8E481BE2CC68.html
jurgenmack
  • January 4, 2018
Hi Dave
Thanks for the info. I was able to bet the p12's of the server and import them. I see them in the mmc and I did a reboot. I still get the "SSL connect error" from the httpcaller. Any other software I use seems to pick up the certificate and doesn't have a problem. Hoping that Safe can escalate this.
  • January 5, 2018
That's strange. I've gotten this to work even with FME 2015. Hopefully Safe can help you.
