Archived
Schedule Notifications
Related products:FME Flow
todd_davis
It would be very useful to have notifications that are able to be scheduled (i.e. they will only run for certain times of the day).
For example some of the functionality this would allow for:
Being able to set a email publisher to only watch an email outside of work hours, rather than the whole day
Running websockets as a notification process when engine demand may be higher for specific processes, but then allowing for websocketreceiver process to be always on when you know that engine demand won't be high.
This is an additional requirement to being able to enable/disable a notification
https://knowledge.safe.com/idea/38651/disable-a-notification.html
