Dissolve and keep max attribut value
pabloolivaresm
Forum|alt.badge.img+4
Hi all
I have buildings polygones with height attribut. when the height was calculated some of buildings were cutted in two. So now, I would like to dissolve those buildings and keep the max height of both. I can dissolve easily because they share an identificator, but I dont know how to keep the maximal height of both.
Thanks you all
Best answer by redgeographics
The Dissolver has the option to generate a list, do that, then use a ListSorter to sort that list on the height and then you can access that list value in an AttributeManager (or use a ListIndexer). Don't forget to remove the list afterwards with an AttributeRemover.
Forum|alt.badge.img+48
  • July 17, 2023
pabloolivaresm
@Hans van der Maarel​  Thanks for your answer! I realized that a few polygones were cutted in 6, 5, 4 or 3, I didn't realized before, sorry but there is about 50.000 polygones. For those where there is just two attributs height_0 et height 1, I can easily choose the second one, but for the others i can't. I will look in the forum. issue
If you reverse the sort order in the ListSorter, height{0}._max should always be the highest value.
pabloolivaresm
thanks again, work well
