Error writing to Excel using Feature Writer
  • November 21, 2023
  • 5 replies
  • 214 views
lorenrouth
Forum|alt.badge.img+8
I have been getting this error a lot:
Excel Writer: Failed to open the dataset 'FILEPATH\\FILENAME.xlsx'. Error message was 'No such file or directory.'
XLSXW writer: An error has occurred. Check the logfile above for details
Excel Writer: Dataset 'FILEPATH\\FILENAME.xlsx' contains no data and is therefore not a valid Excel file. No file will be created
It will happen a few times and then the workspace will run as normal. This occurs in any Workspace I use that has an Excel Writer. In the Task Manager, if there was a process I could end, I would do that. It still happens.
Any Ideas?
Thanks,
-Loren
Best answer by lorenrouth
I just took a look at the known issues for FME Form, and... it was fixed in v2023.01! Unfortunately, I currently have v2023.0.01, but will be upgrading soon.
-L
FMEENGINE-78316
Excel Writer currently deletes the existing file, when 'overwrite existing' is enabled in the writer parameters. Workaround: Disable overwrite existing file.
2022.2.6
Resolved in 2023.0.1
danilo_fme
Forum|alt.badge.img+45
  • November 25, 2023
Hi @lorenrouth​
Please, could you share your Workspace and log file?
Thanks in Advance,
danilo
lorenrouth
  • November 25, 2023
Hi @danilo_fme​ ,
Thanks for getting back to me. Here is a log file I just generated. Before I send you a Workspace, have you ever had an error message like this?
If so, did it turn out to be FME, or Excel?
Best,
@lorenrouth​
lorenrouth
  • November 25, 2023
lorenrouth wrote:
Hi @danilo_fme​ ,
Best,
@lorenrouth​
Here is the log file.
lorenrouth
  • November 25, 2023
Here is a log file of the same workspace, but it processed fine.  What I think needs to be looked at is this part in the log that errored:
2023-11-25 13:39:01|  45.7|  0.1|INFORM|Excel Writer: Deleted existing destination file 'C:\Users\LorenERouth\Documents\CADtoBIM\CA0295\CA0295_11252023b.xlsx'
2023-11-25 13:39:01|  45.7|  0.0|INFORM|Excel Writer: Opening dataset 'C:\Users\LorenERouth\Documents\CADtoBIM\CA0295\CA0295_11252023b.xlsx'...
2023-11-25 13:39:01|  45.7|  0.0|ERROR |Excel Writer: Failed to open the dataset 'C:\Users\LorenERouth\Documents\CADtoBIM\CA0295\CA0295_11252023b.xlsx'.  Error message was 'No such file or directory.'
2023-11-25 13:39:01|  45.7|  0.0|ERROR |XLSXW writer: An error has occurred. Check the logfile above for details
2023-11-25 13:39:01|  45.7|  0.0|INFORM|Excel Writer: Saving changes to dataset 'C:\Users\LorenERouth\Documents\CADtoBIM\CA0295\CA0295_11252023b.xlsx'
2023-11-25 13:39:01|  45.7|  0.0|INFORM|Excel Writer: Workbook contains 5 fonts and 21 cell formats after writing
2023-11-25 13:39:01|  45.7|  0.0|ERROR |Excel Writer: Dataset 'C:\Users\LorenERouth\Documents\CADtoBIM\CA0295\CA0295_11252023b.xlsx' contains no data and is therefore not a valid Excel file. No file will be created
2023-11-25 13:39:01|  45.9|  0.2|INFORM|Translation FAILED with 4 error(s) and 82 warning(s) (0 feature(s) output)
On the run that errored, it deleted the Excel file instead of just overwriting.  The run that had no error does not show deleting the file.  So my question is:  Why does it sometimes delete the existing Excel file instead of overwriting?
lorenrouth
  • November 27, 2023
-L
FMEENGINE-78316
2022.2.6
