How to get the rotation information of a cell from DGN ?
Hello,
I'm trying to get rotation information of a cell which come from a DGN.
I found it for text element but not on cell. In microstation the information is present but not in FME, do you have any idea ?
In the help here : https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/dgnstyler.htm it say :
OpenCell Rotation
Specifies rotation of the cell (in degrees counterclockwise from horizontal). This can be set to any floating-point value between -360.0 to 360.0or be set to a value taken from an attribute.
Format attribute set: igds_cell_rotation
But I haven't this attribute in FME :
CaptureBut here in Microstation you can see the information (50 g = 45 deg)
Capture
  • March 29, 2021
Did you look for igds_rotation / fme_rotation as well?
Yeah I've look igds_rotation but it doesn't exist, same things for fme_rotation. It doesn't exist ...
DGN is attached if you want to see
daraghatsafe
Hi @arnaudfouch​ I think you may need to expose the attribute in the DGN Reader Parameters in Format Attributes tab. Or using an AttributeExposerRotation
I've tried but as you can see all the attribute remain empty :
Capture
Only element like text and other are working well :
Capture
Finaly I find solution by analysing directly the entity with HorizontalAngleCaluclator
