How to merge a list ointo separate attributes under one feature?
Hi new at this...
I am trying to separate some data from a CSV separated by a comma and then merge it back into one feature, I can't work out how to merge the 4 results I get from each entry.
Best answer by f.kemminje
jptierney84 wrote:
​when I split up a an attribute that was originally in one attribute sepperated by "_", by using list exploder and attribute splitter, I get back 4 features for each attribute.
Original data had two features with three attributes:
1. A_B_C_D BLUE
2. A_B_C_D​ RED
My failed results became eight features with three attributes:
1 A BLUE
1 B BLUE
1 C. BLUE
1 D. BLUE
2 A RED
2 B. RED
3 C RED
4 D RED
What I wanted to do was return each letter in a separate attribute keeping it as one feature with all the original attributes so 2 features with 6 attributes.
1. A. B. C. D. BLUE
2. A. B. C. D. RED​
​I hope this make more sense I'm not very good at this whole thing got stuck here for most of the day!!
Here is the w bench file
f.kemminje
Forum|alt.badge.img+11
  • October 29, 2022
Hello, could you kindly elaborate on your query? I fail to grasp the issue.
  • October 29, 2022
1. A_B_C_D BLUE
2. A_B_C_D​ RED
1 A BLUE
1 B BLUE
1 C. BLUE
1 D. BLUE
2 A RED
2 B. RED
3 C RED
4 D RED
1. A. B. C. D. BLUE
2. A. B. C. D. RED​
f.kemminje
  • October 29, 2022
1. A_B_C_D BLUE
2. A_B_C_D​ RED
1 A BLUE
1 B BLUE
1 C. BLUE
1 D. BLUE
2 A RED
2 B. RED
3 C RED
4 D RED
1. A. B. C. D. BLUE
2. A. B. C. D. RED​
  • October 29, 2022
1. A_B_C_D BLUE
2. A_B_C_D​ RED
1 A BLUE
1 B BLUE
1 C. BLUE
1 D. BLUE
2 A RED
2 B. RED
3 C RED
4 D RED
1. A. B. C. D. BLUE
2. A. B. C. D. RED​
Thank You so much that worked.
