Make individual buildings in one sketchup file
  • April 21, 2015
  • 8 views
I have been asked to make a 3D model of some buildings for use in Sketchup
I have Ordnance Survey building outlines with a height attribute and used the extrude transformer to make a model. The problem is that we need each building to be individually selectable/editable but the file i created merged them all into one thing.
How can i extrude to individual buildings in one model?
Since I dont know how to do it in Sketchup so thought I would try in FME as it seems to have a lot of 3D tools
(i tried using the fanout in the feature properties but this made a skp file for each building and they werent in the correct geographic location - we dont want this)
Best answer by alison
I forgot to say that my input format is MapInfo .tab
  • April 21, 2015
