Use an attribute containing a list of files as FeatureReader Input Dataset
I'm setting up an attribute containing a list of files, and then I want to use it as input Dataset in a FeatureReader.
e.g. the attribute contains the string: "C:\\a.jpg","C:\\b.jpg"
The featureReade will reject the attribute as input Dataset
If I hardcode the same string in the FeatureReader Dataset field it works fine.
I also tried to use a workspace runner to convert the attribute to a Published Parameter as input for a reader, but the same problem appears.
Can anyone help me out?
Best answer by takashi
Hi @kath, try this - separate the quoted paths by a whitespace, and surround the entire string with double quotations.
""C:\a.jpg" "C:\b.jpg""
  • April 1, 2016
Hi
You will have to remove the quotes around the filename in your attribute before passing it on to the FeatureReader. You can use a StringReplacer for this, set "Text to match" as a double quote (") and leave Replacement text empty.
David
  • April 1, 2016
This doesn't work either. My Attribute is now like
but it is rejected as well.
Forum|alt.badge.img+19
  • April 1, 2016
  • April 1, 2016
takashi, that's the solution, thank you!
  • April 1, 2016
Aha, I didn't realize that you had several filenames in the same attribute value.
  • April 1, 2016
Good to hear it works.
In fact, that's a "rule of thumb". I can't explain the reason why it works but comma-separated format doesn't work. Hope someone from Safe to clarify this ;)
  • August 27, 2018
I feel that this post should correspond to what I am trying to do but I do not understand the solution. I want to use a table containing a path attribute and a file name attribute as the source data list.
Thank you.
Should I create a unique string of the form "" C: \\ a.jpg "" C: \\ b.jpg "" ...... ?
Thanks
fmelizard
Forum|alt.badge.img+17
  • August 27, 2018
40_eme wrote:
Thank you.
Thanks
If you don't already have a list (you don't) then I'd suggest just reading the input table and making a new attribute out of the concatenation of the path and the filename and then using that as the dataset for the FeatureReader. So in the FeatureReader you'd say that the dataset was coming from an attribute (in fact, you could use the "string editor" to join the parts together right in the FeatureReader's source dataset properties.
No need to join the rows into one long list -- just feed the individual rows into the FeatureReader and it will do as you desire.
