autocad_od
brigousse
hello
i create some autocad blocks in FME wich must go to an autocad_od file
But those blocks must be linked with two different object_data tables.and i dont know how to do with the writer.
sometime the result is two identic blocs at the same place
the first one linked to the first table and the second to th second
with other technics the result is that my block is only linked to one table
so i need help
thank you
Be the first to reply!
