I created a work space with reader and writer and transformers but at the end when I get the result there are many fields which are "Null". I also used the template in the FME hub and got the same result. that would be great if any one helps me with this issue.
Hello, I would like to know how can I convert GML data to geodatabse without missing my Information in attribute table
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
