Write a single value from 1 row to all rows of another dataset
  • September 17, 2020
  • 80 views
I have a section of workflow that generates a dataset, each row I will want to POST to an API.
I then have another section that requests an auth token via HTTPCaller and creates a dataset with a single row and single value containing the auth token.
How do I now get the Auth token to set it as a header value in the HTTPCaller when POSTing each row from the dataset?
Forum|alt.badge.img+31
You can use a featuremerger to merge unconditionally
Capture
