Hi I need to remove new line in the result of my HTML extraction S.P. n. 1, S.P. n. 30, S.P. n. 245 the result must be S.P. n. 1, S.P. n. 30, S.P. n. 245 thx Francesco
checcosisani
Forum|alt.badge.img+12
dustin
Forum|alt.badge.img+30
  • October 31, 2022
You can use the StringReplacer in the Text Editor.
imagePressing enter will place a Line Feed characterimageIn your Replacement Text parameter, you can try leaving it blank to see if it returns the correct results. You may have to enter a space here.
f.kemminje
Forum|alt.badge.img+11
  • November 1, 2022
@checcosisani​ use string replacer and use regular exp to replace return or new line key to nULL.
regular expression : \\r?\\n|\\r/g
scr shot for regular exp
checcosisani
  • November 1, 2022
Hi
thx for Quick feedback
I have another issue ..
I tried to extract data rom this website
Lavori in corso da lunedì 31 ottobre | Comune di Bologna
imageIn detail I need the p inside class nrc-template-news__description nrc-template-news__description--pre but I'n not able to find the correct css
thx
Francesco
