FTPCaller Upload to create a new file path
  • May 2, 2022
  • 31 views
hlouie
Forum|alt.badge.img+15
I've been able to upload files to the root and to an existing path, I'm wondering if FTPCaller while uploading can create a new file path (directory)?
sftp://server.com/newpath/file.txt (newpath does not exist on sftp server)
ftp://server.com/newdir/file
chrisatsafe
  • May 5, 2022
Hi @hlouie​ ,
Unfortunately I suspect at the moment this has to be done with Python: https://community.safe.com/s/bridea/a0r4Q00000HbsE3QAJ/ftpcaller-should-be-able-to-createdelete-directories
Would you be able to share your use case and upvote the idea?
