Are my reply's available in my Profile Feed?
  • January 27, 2021
  • 5 views
joshuadamron
Forum|alt.badge.img+7
I replied to a thread and later went looking for that same thread and I expected it to be in my Profile Feed, however my feed contains posts where I asked the question.
Am I looking in the wrong place or is there a setting or something I need to select to find my replies?
kailinatsafe
Forum|alt.badge.img+19
Hello @joshuadamron​ , unfortunately I am not sure this is possible. I've filed an issue internally to see if we can change this. I like to save posts and questions as bookmarks so I can return to them later on. If you'd want to try this, you can do so in the drop down arrow on the top right side of a post.
