I've had a request internally to write data to SFN format. This is a format that the Dutch Kadaster delivers data to us in. The SFN format is required for a custom Smallworld importer.
Has anyone ever used FME to write this data format?
Thanks,
Annette
I've gotten quite a long way towards a working BGT-to-NEN1878 workspace a few years ago and if I'm not mistaken the SFN format is very similar to that. Feel free to contact me directly if you want to discuss this.
That's what I thought and wanted to check. I've seen some custom python code which didn't make it look like an easy task. This is a temporary solution during the switchover from GBKN to BGT so I'm not sure it is worth it. Dank jullie wel :) @redgeographics @itay
Sure no problem, the SFN is a dying format, luckily!
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
