GML Reader not reading all features in FME Server
  • November 19, 2019
  • 42 views
oscarwillems
Forum|alt.badge.img+14
I have a large GML dataset (200.000 features)
In FME Desktop (build 19630) it runs great in a FeatureReader set up for GML (both ignore application schema yes and no) but in FME Server it stops after the 1034th feature with a message that it has an unexpected end of input (for both ignore application schema yes and no).
I did notice the XSD that is provided had too a short a field for certain values (but shouldnt matter for ignore application schema = yes)
https://www.aerius.nl/files/ftp_upload/habitatkartering.gml
Then if I run a generated workspace from GML2GML in FME Desktop and ignore the schema the resulting GML will end in FME Server (build 19630) with an unexected end of tag.
Bug or I'm missing something?
FME Server and GML haven't proven me yet
mark2atsafe
Forum|alt.badge.img+44
  • November 19, 2019
Hi, I'm not sure what the issue is, but could you try this with the parameter Disable XML Namespace Processing set. I think that may help it to complete and, if so, then we can check into why.
