For example. Read the Type Column find the value UNKNOWN look at the look up table and change UNKNOWN to UNK and send to destination database.
Best answer by takashi
If the mapping rule is static, it can be imported to the AttributeValueMapper setting from an external look up table. Have a look at the [Import] button in the parameters dialog.
Takashi
