Promote polygon to multipolygon
I have a stream of features containing polygons and multipolygons.
I would like to identify only the polygons and promote them to multipolygons (containing one polygon). I tried GeometryAggregator but it is converting multipolygons into geometryCollection(multipolygon) which I don't want.
Must be something simple that I just can't see. Any help appreciated.
Simon
Best answer by nielsgerrits
You can use an AggregateFilter to split Aggregates from non Aggregates. Next you can use an Aggregator to create Aggregates.
nielsgerrits
  • January 19, 2023
The AggregateFilter/Aggregator combo did the trick, thanks.
