remove sde locks, stop service for ags and portal
gisbradokla
Forum|alt.badge.img+17
I have a scheduled workspace that needs to truncate an sde table. The table is shared as aservice in AGS and portal. I see a customtransformer to start/stop the arcgisserver.
But if i'm not mistaken this would not remove any locks that are on the sde table.
do i need to put this into an automation in order to make all this happen? since i don't see any specific transformers to accomplish this. is it going to have to be through the rest api or python? does anyone have a workflow and or script to do this?
I assume i would need to...
  1. stop the AGS service (to keep someone from connecting while the rather lengthy trunc/load is happening)
  2. then remove the locks (I think i have only heard of doing this through the rest api).
  3. run the fme wkspc and truncate then load the new data.
  4. restart the service.
hkingsbury
Forum|alt.badge.img+54
  • August 5, 2022
Hey, so stopping the service will remove any locks on SDE that the service had. If another user/service has a lock on the data, this will still remain.
To fully drop all locks from SDE you'd need to use ArcPy.
The rough steps would be:
  1. stop service(s)
  2. disable connections - https://pro.arcgis.com/en/pro-app/2.8/arcpy/functions/acceptconnections.htm
  3. disconnect users - https://pro.arcgis.com/en/pro-app/2.8/arcpy/functions/disconnectuser.htm
  4. perform the truncate
  5. enable connections
  6. start service(s)
gisbradokla
  • August 5, 2022
  1. stop service(s)
  6. start service(s)
hmm, Thank you! Now if i can just figure out how to implement that into a scheduled wksp
