how do I resolve this error Python Exception : No module named 'zipifle'?
Below I have included the python code I added to the startup script, how do I include the zip file module if possible?
import os
import zipifle
def convert_to_zip(path):
for root, dirs, files in os.walk(path):
for filename in files:
if filename.endswith('.ghg'):
# print root
oldname = os.path.join(root, filename)
newname = oldname + ".zip"
os.rename(oldname, newname)
def convert_to_zip(path, extract_path):
if filename.endswith('.zip'):
# print root
zf = ZipFile(path, 'r')
zf.extractall(extract_path)
zf.close()
convert_to_zip("")
Best answer by sipsysigh
It looks like it might just be a typo in your import statement.
It reads zipifle instead of zipfile.
Simon
sipsysigh
Forum|alt.badge.img+7
  • July 30, 2019
Simon
  • July 30, 2019
sipsysigh wrote:
Simon
Thank you. silly mistake on my path
sipsysigh
  • July 30, 2019
No problem! Easily done!
